Help Headphone connected
mehdii
When i start my GTI9300 it said headphone connected but there is not any!! And speakers dont work. Help me plz.thank you
If you have headphone try plugging it in and unplug it again
Sometimes my phone says charging when its not and the only way to make it go away is to plug the charger in and remove it again, restarting I believe also fixes my charge icon but that clearly wouldn't work in your case
K, that's strange, this section isn't directly for that model but we can possibly try to trouble shoot ya
I'm about to head to work so hopefully someone else will also jump in
First let's start basic
List you device- I see you've done this
What ROM u have if any
When this issue started
You can edit the first post with the info or post it right below this one
Most likely if your using a custom ROM and plugging and unplugging a headphone didn't work I'd normally suggest a fresh install as it would be possible something didn't take during flash
Although it could also just be a ROM issue
If your on stock still would be the really unsure situation cause then it could be hardware or software failure
My phone is Gti9300 32GB
This issue started last year but i didnt care till now.
I dont know anything about ROM.
When i turn on my phone it says headphone connected but as soon as i make a call it will be ok and speakers works good but when i plug in headphone doesnt work.
Are you using our mk5 rom for your phone I always get the message says headphones disconnected upon reboots but it works if your using mk5 it might be your hardware doesn't work with mk5 rom try your stock rom or a custom rom made for your phone
Our phones are L710
