Help Headphone jack problem?
febreeezy
Hey all,
My HTC amaze has a little bit of headphone jack issue, or so I believe. Here's the issue: when I have regular headphones plugged in they always tend to slip on just enough to create a disconnect. However, headsets (with microphone capabilities) tend to almost lock in and I do not have this problem. I noticed that the headphone plug is somewhat different than the headset plugs as they have only 2 black ring when compared to the headsets (3 black rings). I can assure you the headphones are in perfect working order. Is this a defect? and should it be covered under warranty?
Thanks for the response. I hope this makes sense.
A 3.5mm plug should be the same regardless of mic'ed or not, but I've noticed very slight variations from one manufacturer to another. Take it into a store if you can and try some in-store demo headsets.
