Help Headphones not detected, ToggleHeadset2 crackling audio
superlou
The other day the headphone port on my Atrix stopped detecting plugged in headphones. I tried a couple different pairs to be safe, and all the headphones work with other audio sources. Playback from the phone speaker works fine.
I've looked into the headphone port and don't see any large pieces of lint near the contacts, though it looks like there's something white at the bottom of the port past the third contact. If someone with a working port could look into theirs and let me know if that's normal, I'd greatly appreciate it.
I found that if I use ToggleHeadset2 to force audio output, I can hear crackling from the headphones, so long as the volume is at the highest one or two levels.
I've tried tapping the phone in various locations, so I don't think it's a bad solder joint, and the phone hasn't gotten wet recently.
I was wondering if anyone else has had a similar problem? My phone is past warranty, and apparently the deductible is more significant than thought, so I'm open to pretty much anything.
Embarrassing resolution: it was lint. If anyone else has a similar issue, there is another contact at the base of the headphone port. If you can't see it, you have enough lint to cause problems.
