Root Head's about ready to explode
heywood
i followed all the instructions to root the eris and i'm pretty sure all has gone well.
Just to preface, i am technically adept. Just no linux/android experience ever.
So while I believe for the most part all is ok, I still have some problems.
The phone is rooted, while running normally & attached to the pc in usb debugging mode, from the command prompt doing an adb shell only gets the $.
So i figure maybe i did something wrong, i know i can see i've made the right steps when doing a vol up + power on, so i find drocap, a root only app. I install it, i'm able to take screen caps no problem.
So i figure let me try booting into recovery mode, NOW when i type adb shell i get the #
So I wanna see if i can remove some of the apps I don't want
"mount -o rw,remount /dev/block/mtdblock3 /system"
works fine
"Now type "cd /system/app" and then "ls"
works great, i can see all the apps but it still isn't letting me delete.
That was in the afternoon.
I took a break, had dinner, tv, when i returned....whatever it was i did earlier just evaporated
I don't know if i omitted anything but when i do
"cd /system/app" it says it's invalid, but if i do a plain "ls" then i can see all the folders of the phone but i can't get back to that system\app folder
what am i doing wrong ?
thanks for your patience
open a command prompt in your /tools/ dir of the sdk, type adb shell and then su...you will then get a prompt on your phone, hit always allow. then you all set
sir, you are a lifesaver
and if a mod is reading, please insert that valuable piece of into into the deleting unwanted apps thread
thanks
dont forget the thanks button, hehehe...glad i could help...i had same problem and was going to kill myself as well, lol
