Root Heelp!!! my phone stuck to model name text with yellow triangle
ebelisti
ArtMy phone stuck witth yellow triangle. My phone is galaxy trend gt-s7560 I rooted it couple of weeks ago. It worked well but now I wanted to try custom roms. I press install to rom it rebooted my phone and now here is the yellow triangle. I don't no what to do.
I'm very happy if someone can help me pls :)
Samsung devices have a binary counter their devices to detect unofficial software flashed. You can follow the steps in this post, or download Triangle Away by Chainfire
AS ALWAYS, THE AUTHORS OF THEIR RESPECTIVE POSTS, INCLUDING MYSELF, TAKE NO LIABILITY FOR CONSEQUENCES OF FOLLOWING THE STEPS LISTED There is a slight risk that TriangleAway can brick you,so be careful.
Its best to use one that you easiest understand. But if you didn't know how to fix this problem should it happen. You should under no circumstance be flashing ANYTHING.. if you don't fully understand root. Recovery. Flashing. Adb. SDK. Command line. And aosp... Don't ever mod anything until you have innate knowledge of all those. Or a lot of money to have experienced knowledge.
I know others have given you a way past the yellow triangle --- I just want to make sure you are not at the TWRP yellow triangle. Do you know what recovery rom you installed? TWRP? CWM? TWRP has a yellow triangle and you can get into a fastboot loop with TWRP which is unrelated to the other discussion.
As others stated ODIN is your friend.
uDude
