Helix Launcher...
xAusTiN
Just installed it on my Eris because I wanted to check it out....but I can't figure out how to customize it and everything.
And also what are the benefits or anything else about Helix?
Any help would be appreciated!
EDIT: I don't know if this has any affect on it, but my phones not rooted.
if you have it set as your home, then just press menu then configure. Otherwise you just drag and drop from you app tray onto the home screen. You can set four icons on the very bottom next to the app tray as static shortcuts that will be available from all screens.
