Welcome to AF, LyraVanessaMay! No worries, it happens
P.S. Android uses specific resolutions and sizes for wallpapers, depending on the phone. If the resolution of the original picture is too high, you will only be able to take a small portion of it. Try using image editing software to reduce the resolution, that should help with your issue.
