Apps hello / tryingg to find correct forum
metulburr
Hello all
I was trying to find the developer forum, but i dont see it anywhere?
I have setup eclipse, with a basic hello world app, and trying to run it in my android. Under developer options, i have USB debug selected. However nothing happens when i hit "run" on eclipse under my app. I have connected the device before as i drag and drop movies to my internal memory.
So what might i be missing?
Ubuntu 13.04
android 4.1.2
Galaxy Tab 3
I used the ADT bundle here http://developer.android.com/sdk/index.html for linux
Hi metulburr ... :)
Welcome aboard.
Hopefully you'll find our community useful -- I've moved your thread to where you'll most likely get the answers you seek.
Best luck.
sounds like you need to setup your hardware testing device.
In windows eclipse theis is done under menu
window and
Android virtual device manger
HIH
Steve
OK, i apparently have fixed it. since creating the app, i restarted eclipse after saving my changes to the app. Then when i start it back up, and red othe process. I get the page that asks to use the linked device, etc. and it wokrs at that point. I havent had a problem since. That is quite odd.
