hellppppp android lg optimus from metropcs
khawla
heyy plez help so i got my fone and a week later i got it in water...:( i put it in rice..n that rlly works i put for like 4 days n i works for 2 months comletllllyyy welll u noe.. n noe its going crazii i presss on txt n it takes me there but i try to exit n it doesnt let me it keep on showing my recenst n im nott even pressing that.. everyone mite think its the watter dmage but i higghlyy doubt it cuz my fone n ipod fell in water n the rice totally fixed them n ive had them for like 1 year nd 2 years so yehh plez help if u can also i restted it but didnt do nything :(
Welcome to Android Forums.
You'd be surprise what kind of potential damage a dunk can do to electronics. Even if the phone dries and works well for a while, that small amount of time with the moisture can start the corrosion process. Once that gets going, it's only a matter of time.
You could try pulling the batter, sim and SD card and cleaning all the contacts with a little alcohol and performing a factory reset. But i fear it may be residual water damage for you.
