Root help a rooting noob
for rooting and roms i keep seeing instructions saying put the root tool or rom on the sd-card then do the maintance mode and run the zip from there.
can this be done from a pc over usb as i can never access or see the file structure on my pc?
do i have to use the sd card as a separate media out of the phone to put the files on their? ive not tried this yet as i dont have an adapter for the pc.
You just have to put the zip file on the sd card, you can do that using a card reader or connecting the phone to pc through the usb cable.
After that you need to restart the phone into recovery mode and install that zip file.
