Help HELP! Accidentally deleted android stock keyboard!
kass2112
Hi, i accidentally deleted the android stock keyboard and i was updating my phone but the update didn't work so clicked wipe data, and the motorola setup comes up but when i want to put my email the keyboard does not come up! Is their any way i can install the keyboard?
That is strange. A motorola update is not supposed to remove the keyboard. You should try to re-install the update or try to update to the latest available system. Make sure you have enough space on your memory card and phone internal memory.
