hey im making a simple android application (basically its my first app after helloworld) .. i have an edittext and a button in main.xml and what i want is when that button click .. the text written in the edittext should b displayed in a dialog box .. these are the codes
code of main.xml
code of strings.xml
code of main.java
and whenever i run this app ... it crash ... and in logcat i get this error
so any1 can help me with that... i dont know where im going wrong ...
P.S. im new in this forum so will spend tym to understand it also
code of main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:weightSum="1">
<EditText
android:layout_height="wrap_content"
android:text="@string/txt"
android:id="@+id/txtName"
<Button
android:id="@+id/btOk"
android:text="@string/bt"
android:layout_width="206dp"
android:layout_gravity="center"
</LinearLayout>
code of strings.xml
Code:
<resources>
<string name="hello">Hello World, main!</string>
<string name="app_name">ProjectTest</string>
<string name="txt">Enter Your Name</string>
<string name="bt">OK</string>
</resources>
code of main.java
Code:
package com.toor.projectTest;
import android.app.Activity;
import android.app.AlertDialog;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
public class main extends Activity {
/** Called when the activity is first created. */
public Button btOK ;
public EditText editName = new EditText(main.this);
public String getName = new String();
AlertDialog.Builder alertBox = new AlertDialog.Builder(main.this);
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
editName = null;
getName = null;
editName = (EditText) findViewById(R.id.txtName);
btOK = (Button) findViewById(R.id.btOk);
getName = editName.getText().toString();
btOK.setOnClickListener(new OnClickListener() {
@Override
public void onClick(View v) {
// TODO Auto-generated method stub
alertBox.setMessage(getName);
alertBox.show();
07-09 06:59:15.296: ERROR/AndroidRuntime(763): FATAL EXCEPTION: main
07-09 06:59:15.296: ERROR/AndroidRuntime(763): java.lang.RuntimeException: Unable to instantiate activity ComponentInfo{com.toor.projectTest/com.toor.projectTest.main}: java.lang.NullPointerException
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2585)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2679)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.ActivityThread.access$2300(ActivityThread.java:125)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2033)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.os.Handler.dispatchMessage(Handler.java:99)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.os.Looper.loop(Looper.java:123)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.ActivityThread.main(ActivityThread.java:4627)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at java.lang.reflect.Method.invokeNative(Native Method)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at java.lang.reflect.Method.invoke(Method.java:521)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:868)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:626)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at dalvik.system.NativeStart.main(Native Method)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): Caused by: java.lang.NullPointerException
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.content.ContextWrapper.getResources(ContextWrapper.java:80)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.view.View.<init>(View.java:1810)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.view.View.<init>(View.java:1856)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.widget.TextView.<init>(TextView.java:327)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.widget.EditText.<init>(EditText.java:55)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.widget.EditText.<init>(EditText.java:51)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.widget.EditText.<init>(EditText.java:47)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at com.toor.projectTest.main.<init>(main.java:14)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at java.lang.Class.newInstanceImpl(Native Method)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at java.lang.Class.newInstance(Class.java:1429)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.Instrumentation.newActivity(Instrumentation.java:1021)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2577)
07-09 06:59:15.296: ERROR/AndroidRuntime(763): ... 11 more
