liquid_cow
With great expectations and hopes for finally getting a stable phone I installed Suji ROM. I did a full charge and hit battery cal and proceeded to use the crap out of the phone to see how I like it and I like it... until things went wrong late yesterday.
I was purposefully letting the batter drain down, I was at about 15% (which is the trigger level of my Juice Defender so I'm suspecting this is where things went wrong).
I was downloading a map for an ap when suddenly my SD card popped up a warning that it was blank and needed a reformat. At about the same time my cell signal indicator started flashing from bars to the "no" sign. I assumed it was due to low battery so I let the battery run out and charged it overnight.
Reboot, showing 100% charge and still SD card warning, no cell signal. I went into settings and found the "airplane mode" toggling itself on and off about 1 cycle per second. Several reboots, deleted the new aps I added yesterday, still no cell phone signal, though wifi is working. I've disabled Juice to no avail. Have pulled the battery, have removed the SD card, still no cell signal.
Since my backup is on my SD I can't reload until I clear up that issue. Don't have a micro SD reader to plug into other than the phone. I'm tempted not to believe the card is FUBAR since both the card and the cell issue popped up at the same time, I think its a glitch somewhere.
Battery is being consumed at a fairly fast rate and according to System Lite my CPU is constantly cycling from 100% to 50% and back once a second (matches the airplane mode) The only ap showing more than a couple of seconds run time is "System" and that's only got 2m40sec on it.
Answers to obvious Q's:
.602, I did not do the 605ota prior to ROM.
Fusi ROM and I made sure all the software was correct before installing
Juice Defender with stock settings
TiBU Pro
ROM Toolbox with the CPU underclocked at 800
ROM Manager
Not sure if this is a trait of Suji, but I just went to the system panel and hit About Phone to see which versions were showing, the info screen popped up and immediately went away.
Plan for now is to try to flash the sbf and restore to orriginal. Luckily I backed up my SD to my PC yesterday before installing the ROM.
If you have any advice or tips I'd appreaciate it. I'll update as I go.
TiBU Pro
ROM Manager
