Help and advice
Don Mac
Hi...I downloaded an APP for my HTC Desire a while back, which I cant remember what it was called. I had to reset my phone! The app bascially allowed me to use the standard HTC internet ICON on the homepage of the phone, however when I tapped it, it opened my Dolphin bowser. I remember using the app to do that. Does anyone know what this APP is called. Cheers.
Hi
Not sure about an app but there is another way of doing it.
Go into "manage applications" and clear the cache for the stock internet app.
Once you've done that browse for an internet page like normal and it should offer you an option to open the page using the stock app or your downloaded browsers (Dolphin, Opera etc). Tick the box and it should remember that option as the default browser going forwards. You can then just long press your homescreen and then put the internet icon on your homescreen as a shortcut.
