Help and enlightenment please?
zuben el genub
Extreme Android User
I had a problem trying to install Hacker's Keyboard on a rooted Galaxy S 4G.
Early Mon was really good about helping with troubleshooting, and said I should contact the developer. I have contacted the developer and received a reply:
I did get an answer from the developer. I will be heading to his site to see if I can get the info he wants. If I have a problem, can you help explain?
Here's the text of the email:
Comment #1 on issue 144 by Klaus.We...@gmail.com: Will not run on Galaxy S 4G from TMobile.
Issue 144 - hackerskeyboard - Will not run on Galaxy S 4G from TMobile. - Hacker's Keyboard, a 5-row keyboard using full PC key layout for Android tablets or phones - Google Project Hosting
It does sound plausible that there's something confused on the phone, maybe the built-in keyboard isn't willing to relinquish control and spins in a loop.
Are you able to retrieve logs from the phone as a clue towards what's happening? You can use an app on the phone to do so or use USB with the "adb" developer tool, more here:
FrequentlyAskedQuestions - hackerskeyboard - Frequently Asked Questions - Hacker's Keyboard, a 5-row keyboard using full PC key layout for Android tablets or phones - Google Project Hosting
Thanks again.
I'm not sure about the software the developer is asking for. What else does it do besides a log, and the exact steps for editing out personal info. I have a bad habit of going too fast at times, then can never find the instructions again.
Thanks
So, probably you want to check out aLogcat, free in the Market.
Reboot your phone, make no calls, start aLogcat - then home key the homescreen so it's still running.
Open an app - SMS - select to change to Hacker's Keyboard for input. After it dies, reselect your working keyboard.
Long press home, go back into aLogcat, and menu-pause the logging display.
Select menu-share and email to yourself. Review the log for personal info (there is likely to be none, honestly, but check anyway) and then forward that to the dev, along with these instructions followed so he can correlate your steps to things he sees in the log.
Let me know if you hit any snags.
PS - Android maintains a running log as it operates, and resets it on reboot. aLogcat or adb commands simply let you see the existing log - they don't create it or anything.
I got the aLogcat file, looked thru it, and don't see much personal except for a list of programs on the SD card.
If I message it to you from here, can you let me know which are the pertinent bits to send?
I have it saved as a txt file.
I'll freeze aLogcat and Hacker's Keyboard for now.
Thanks
aLogcat file complained it couldn't find user dictionary. I tried running HK before I removed the stuff from Samsung with the same result. I don't use suggestions, autocorrect or spellchecker, so there was nothing in the dictionary but what came with the phone.
It's best to send the entire log sequence so that if there are interactions, the dev can see those - otherwise, he'll know well enough how to quickly search for messages specifically concerning the keyboard issue only.
Following my procedure, that would result in a sufficiently short log, even though it probably may seem long at first glace for just a few seconds or minutes of actual work.
But let me know if you'd still like my review first. :)
Here:
E/Environment( 695): getExternalStorageDirectorySd :: invalid call
I/dalvikvm( 851): Total arena pages for JIT: 11
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 13
V/AudioPolicyManager( 83): getNewDevice() selected device 0
V/AudioPolicyManager( 83): setOutputDevice() output 1 device 0 delayMs 0 force 0
V/AudioPolicyManager( 83): setOutputDevice() setting same device 0 or null device for output 1
D/dalvikvm( 695): GC_EXTERNAL_ALLOC freed 328K, 50% free 3143K/6215K, external 2204K/2208K, paused 27ms
D/dalvikvm( 133): GC_EXPLICIT freed 653K, 42% free 6495K/11015K, external 6662K/7823K, paused 94ms
D/dalvikvm( 317): GC_FOR_MALLOC freed 455K, 46% free 3646K/6663K, external 1596K/2108K, paused 40ms
I/CheckinService( 317): Preparing to send checkin request
I/EventLogService( 317): Accumulating logs since 1326053481501
W/DiskCacheSEC( 695): enter writeIndex 128
W/DiskCacheSEC( 695): Create TempFile = /sdcard/DiskCacheIndex1586616420.tmp
V/DiskCacheSEC( 695): [SE Lab.] writeindex(): id= 1243946720 / mntTime= 1326053530330
D/DiskCacheSEC( 695): Wrote index with 128 records.
W/DiskCacheSEC( 695): rename to = /mnt/sdcard/Android/data/com.cooliris.media/cache/local-image-thumbs/index
D/dalvikvm( 695): GC_EXTERNAL_ALLOC freed 287K, 50% free 3144K/6215K, external 2117K/2160K, paused 29ms
D/ResourceType( 317): calling getConfigurations
D/ResourceType( 317): called getConfigurations size=156
I/CheckinTask( 317): Sending checkin request (1149 bytes)
D/Finsky ( 851): [1] 1.onResponse: Phonesky checkin succeeded for account
D/Finsky ( 851): [1] 1.attemptNextSync: Done checking in.
D/FastDormancy( 231): before ======= ENTER DORMANCY =======
D/FastDormancy( 231): [FD] ON default: true
D/FastDormancy( 231): Before mDormFlag: false in getCapaDormancy()
D/FastDormancy( 231): After mDormFlag: false in getCapaDormancy()
D/dalvikvm( 695): GC_EXTERNAL_ALLOC freed 264K, 50% free 3145K/6215K, external 2156K/2160K, paused 22ms
E/Sensors ( 133): LightSensor: debouncing current adc(625), report prev lux 5000.000000
D/UriTexture( 695): createFromUri: uri, strPath = content://media/external/images/media/522,/mnt/sdcard/DCIM/Camera/APOLL03.JPG
D/dalvikvm( 695): GC_EXTERNAL_ALLOC freed 131K, 49% free 3175K/6215K, external 1792K/2160K, paused 26ms
D/dalvikvm( 236): GC_EXPLICIT freed 142K, 45% free 3264K/5831K, external 1596K/2108K, paused 25ms
D/UriTexture( 695): createFromUri: uri, strPath = content://media/external/images/media/526,/mnt/sdcard/ImageShrink/13171400380380.jpg
D/dalvikvm( 695): GC_EXTERNAL_ALLOC freed 114K, 49% free 3174K/6215K, external 1696K/2160K, paused 26ms
I/CheckinTask( 317): Checkin success: https://android.clients.google.com/checkin (1 requests sent)
I/CheckinService( 317): From server: Intent { act=android.server.checkin.FOTA_CANCEL }
D/UriTexture( 695): createFromUri: uri, strPath = content://media/external/images/media/530,/mnt/sdcard/ReducePhotoSize/save_as/20110211_183007a.jpg
D/dalvikvm( 695): GC_EXTERNAL_ALLOC freed 92K, 50% free 3169K/6215K, external 1648K/4720K, paused 23ms
D/UriTexture( 695): createFromUri: uri, strPath = content://media/external/images/media/532,/mnt/sdcard/ReducePhotoSize/save_as/20110213_181541a.jpg
D/UriTexture( 695): createFromUri: uri, strPath = content://media/external/images/media/533,/mnt/sdcard/ReducePhotoSize/save_as/Shoes2.jpg
W/DiskCacheSEC( 695): enter writeIndex 150
W/DiskCacheSEC( 695): Create TempFile = /sdcard/DiskCacheIndex1324525798.tmp
V/DiskCacheSEC( 695): [SE Lab.] writeindex(): id= 1243946720 / mntTime= 1326053531576
D/DiskCacheSEC( 695): Wrote index with 150 records.
W/BackupManagerService( 133): Requested unavailable transport: com.google.android.backup.BackupTransportService
E/BackupManagerService( 133): Requested init for com.google.android.backup.BackupTransportService but not found
I/InputReader( 133): dispatchTouch::touch event's action is 0
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '406a6210 Sorry! (server)'
I/PowerManagerService( 133): Ulight 3->7|0
D/LightsService( 133): BUTTON : 236
I/InputReader( 133): dispatchTouch::touch event's action is 1
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '406a6210 Sorry! (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 14
V/AudioPolicyManager( 83): getDeviceForStrategy() from cache strategy 0, device 2
V/AudioPolicyManager( 83): getNewDevice() selected device 2
V/AudioPolicyManager( 83): setOutputDevice() output 1 device 2 delayMs 0 force 0
V/AudioPolicyManager( 83): setOutputDevice() setting same device 2 or null device for output 1
V/AudioPolicyManager( 83): releaseOutput() 1
I/Process ( 882): Sending signal. PID: 882 SIG: 9
I/ActivityManager( 133): Process org.pocketworkstation.pckeyboard (pid 882) has died.
W/ActivityManager( 133): Scheduling restart of crashed service org.pocketworkstation.pckeyboard/.LatinIME in 5000ms
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 14
D/KIPC ( 79): KIPC_SendMessage: len = 4, socket = 14
D/KIPCapp ( 233): doSocketRead returning 2 bytes
D/KIPCapp ( 233): Attempt to read 4 bytes
D/KIPCapp ( 233): calling recv(46)
D/KIPCapp ( 233): doSocketRead returning 4 bytes
D/KIPCapp ( 233): Issuing MsgInd callback, len = 4
E/KINETO ( 233): KLOG082- 01 00 09 02 00 00 00 00
E/KINETO ( 233):
D/KIPCapp ( 233): READ FD = 46
D/KIPC ( 79): Sent 4 bytes
I/Kineto::main( 233): Kineto: WifiAppStatusCallback Enter ganMode: 80
I/TelephonyRegistry( 133): notifyDataConnection: state=2 activeState=2 isDataConnectivityPossible=true reason=networkTypeChanged apn=epc.tmobile.com interfaceName=pdp0 networkType=8
D/MobileDataStateTracker( 133): replacing old mInterfaceName (pdp0) with pdp0 for hipri
I/StatusBarPolicy( 268): onDataConnectionStateChanged-S:2 T:8
I/StatusBarPolicy( 268): updateDataNetType-T:8
D/StatusBarPolicy( 268): Data icon TMO updateDataNetType 4G, Roaming?=false PLMN=310260
D/MobileDataStateTracker( 133): replacing old mInterfaceName (pdp0) with pdp0 for dun
D/MobileDataStateTracker( 133): replacing old mInterfaceName (pdp0) with pdp0 for supl
D/MobileDataStateTracker( 133): mms Received state= CONNECTED, old= CONNECTED, reason= networkTypeChanged, apnTypeList= *
D/MobileDataStateTracker( 133): replacing old mInterfaceName (pdp0) with pdp0 for default
V/RoamingReceiver( 231): action = android.intent.action.ANY_DATA_STATE
D/RoamingReceiver( 231): reason= networkTypeChanged, apnTypeList= *
I/StatusBarPolicy( 268): onSignalStrengthsChanged
E/Sensors ( 133): LightSensor: debouncing current adc(689), report prev lux 5000.000000
W/PowerManagerService( 133): Timer 0x7->0x3|0x0
I/PowerManagerService( 133): Ulight 7->3|0
D/LightsService( 133): BUTTON : 0
D/AudioHardwareALSA( 83): Inside AudioStreamOutALSA::standby
V/AudioHardwareALSA( 83): ALSAStreamOps::close()
I/AudioHardwareALSA( 83): Output standby called!!. Turn off PCM device.
I/ActivityManager( 133): Start proc org.pocketworkstation.pckeyboard for service org.pocketworkstation.pckeyboard/.LatinIME: pid=938 uid=10019 gids={}
I/PCKeyboard( 938): onCreate(), os.version=2.6.35.7-T959VUVKJ6-CL694130
D/dalvikvm( 938): Trying to load lib /data/data/org.pocketworkstation.pckeyboard/lib/libjni_pckeyboard.so 0x40514510
D/dalvikvm( 938): Added shared lib /data/data/org.pocketworkstation.pckeyboard/lib/libjni_pckeyboard.so 0x40514510
I/PCKeyboard( 938): loaded jni_pckeyboard
D/szipinf ( 938): Initializing inflate state
D/dalvikvm( 938): GC_EXTERNAL_ALLOC freed 145K, 42% free 3309K/5639K, external 1596K/2108K, paused 26ms
D/szipinf ( 938): Initializing zlib to inflate
I/PCKeyboard( 938): Loaded dictionary, len=841005
E/ActivityThread( 938): Failed to find provider info for user_dictionary
D/dalvikvm( 938): GC_EXTERNAL_ALLOC freed 858K, 49% free 3344K/6471K, external 3013K/3019K, paused 25ms
I/PCKeyboardIME( 938): attachToken android.os.BinderProxy@40575850
W/dalvikvm( 938): threadid=8: thread exiting with uncaught exception (group=0x40015578)
E/AndroidRuntime( 938): FATAL EXCEPTION: AsyncTask #1
E/AndroidRuntime( 938): java.lang.RuntimeException: An error occured while executing doInBackground()
E/AndroidRuntime( 938): at android.os.AsyncTask$3.done(AsyncTask.java:200)
E/AndroidRuntime( 938): at java.util.concurrent.FutureTask$Sync.innerSetException(FutureTask.java:274)
E/AndroidRuntime( 938): at java.util.concurrent.FutureTask.setException(FutureTask.java:125)
E/AndroidRuntime( 938): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:308)
E/AndroidRuntime( 938): at java.util.concurrent.FutureTask.run(FutureTask.java:138)
E/AndroidRuntime( 938): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1088)
E/AndroidRuntime( 938): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:581)
E/AndroidRuntime( 938): at java.lang.Thread.run(Thread.java:1019)
E/AndroidRuntime( 938): Caused by: java.lang.NullPointerException
E/AndroidRuntime( 938): at org.pocketworkstation.pckeyboard.UserDictionary.addWords(UserDictionary.java:124)
E/AndroidRuntime( 938): at org.pocketworkstation.pckeyboard.UserDictionary.loadDictionaryAsync(UserDictionary.java:71)
E/AndroidRuntime( 938): at org.pocketworkstation.pckeyboard.ExpandableDictionary$LoadDictionaryTask.doInBackground(ExpandableDictionary.java:498)
E/AndroidRuntime( 938): at org.pocketworkstation.pckeyboard.ExpandableDictionary$LoadDictionaryTask.doInBackground(ExpandableDictionary.java:495)
E/AndroidRuntime( 938): at android.os.AsyncTask$2.call(AsyncTask.java:185)
E/AndroidRuntime( 938): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:306)
E/AndroidRuntime( 938): ... 4 more
E/ ( 133): Dumpstate > /data/log/dumpstate_app_error
I/dumpstate( 952): begin
D/BatteryService( 133): update start
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 3985 temperature: 330 technology: Li-ion AC powered:false USB powered:false icon:17302239
D/InputReader( 133): Input event: value=1
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '4079fe00 com.android.mms/com.android.mms.ui.ConversationList (server)'
D/InputReader( 133): Input event: value=0
E/Sensors ( 133): LightSensor: debouncing current adc(753), report prev lux 5000.000000
D/VoldCmdListener( 75): asec list
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.keramidas.TitaniumBackup-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.audubon.wildflowers.mobile.android-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.catamount.pocketmoney-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.lifewaresolutions.dmoon.lite-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.rafdev.astrotoolsalpha1-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'mobi.omegacentauri.LunarMap.beta-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.shoozhoo.imageresizer-2'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.skype.raider-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.slgmobile.beamreader-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.slgmobile.beamreader.key-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.audubon.trees.mobile.android-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.a0soft.gphone.app2sd.pro-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.audubon.mobile.android-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'vortex.planetarium.app.vortex-2'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.a0soft.gphone.app2sd-2'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.audubon.mobile.android-2'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.firedale.messier-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.metago.astro-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'com.shoozhoo.imageresizer-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'larry.zou.colorfullife-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'mobi.mgeek.TunnyBrowser-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> 'vortex.planetarium.app.vortex-1'
D/VoldCmdListener( 75): CommandListener::AsecCmd::runCommand -> --
I/dumpstate( 952): done
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '407d29d8 Sorry! (server)'
V/WindowManager( 133): in interceptKeyBeforeDispatching() KEYCODE_HOME isSystemKeyEventRequested() is false
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '4079fe00 com.android.mms/com.android.mms.ui.ConversationList (server)'
D/Tethering( 133): [kjtemp]ACTION_BATTERY_CHANGED
I/StatusBarPolicy( 268): BAT. S:4 H:2
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '407d29d8 Sorry! (server)'
E/Sensors ( 133): LightSensor: debouncing current adc(646), report prev lux 5000.000000
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '407d29d8 Sorry! (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 15
D/AudioHardwareALSA( 83): Calling setDevice from write @..2071.
I/Process ( 938): Sending signal. PID: 938 SIG: 9
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40831010
I/ActivityManager( 133): Process org.pocketworkstation.pckeyboard (pid 938) has died.
W/ActivityManager( 133): Service crashed 2 times, stopping: ServiceRecord{40899d30 org.pocketworkstation.pckeyboard/.LatinIME}
I/AudioHardwareALSA( 83): Initialized ALSA PLAYBACK device AndroidPlayback_Speaker_normal
V/AudioHardwareALSA( 83): Set PLAYBACK PCM format to S16_LE (Signed 16 bit Little Endian)
D/AudioHardwareALSA( 83): Using 2 channels for PLAYBACK.
I/AudioHardwareALSA( 83): DEFAULT_SAMPLE_RATE is 44100, mDefaults->sampleRate is 44100
D/AudioHardwareALSA( 83): Set PLAYBACK sample rate to 44100 HZ
D/AudioHardwareALSA( 83): Buffer size: 4096
D/AudioHardwareALSA( 83): Latency: 92879
W/AudioFlinger( 83): write blocked for 88 msecs, 5 delayed writes, thread 0x319a0
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 15
D/Mms/ConversationList( 496): onSaveInstanceState
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.sec.android.app.twlauncher/.Launcher } from pid 133
I/Launcher( 303): onResume(). mIsNewIntent : true
E/ ( 303): onResume() check 0
E/ ( 303): onResume() check 1
E/Launcher( 303): setWindowOpaque()
E/ ( 303): onResume() check 2, mRestoring : false
E/ ( 303): onResume() check 3
E/ ( 303): onResume() check 4
E/ ( 303): onResume() check 5
I/Launcher( 303): onResume() ended
I/Launcher( 303): onWindowFocusChanged(true)
D/Launcher( 303): It's image wallpaper. suggestDesiredDimensions(-1,-1)
W/InputManagerService( 133): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@409d9848 (uid=10074 pid=496)
I/ActivityManager( 133): No longer want com.sec.android.app.servicemodeapp (pid 571): hidden #16
D/Mms/ConversationList( 496): [start] onStop()
D/Mms/ConversationList( 496): [end] onStop()
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '407ca5b0 com.sec.android.app.twlauncher/com.sec.android.app.twlauncher.Launcher (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '407ca5b0 com.sec.android.app.twlauncher/com.sec.android.app.twlauncher.Launcher (server)'
D/SamsungUtils( 303): acquireDVFSlock arg0 : 0 arg1 : 1000
I/power ( 133): acquire_dvfs_lock level=0
I/power ( 133): acquire_dvfs_lock level=0, duration=1000, val=1000
D/PowerManagerService( 133): acquireDVFSlock : level : 0, timeMS : 1000
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings bnds=[365,84][475,222] } from pid 303
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 16
I/Launcher( 303): onPause()
W/ActivityManager( 133): Trying to launch com.android.settings/.Settings
D/dalvikvm( 224): GC_EXTERNAL_ALLOC freed 159K, 43% free 3190K/5511K, external 2108K/2108K, paused 37ms
I/Launcher( 303): onWindowFocusChanged(false)
I/ActivityManager( 133): Displayed com.android.settings/.Settings: +297ms
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 16
E/Sensors ( 133): LightSensor: debouncing current adc(799), report prev lux 5000.000000
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '4084fa00 com.android.settings/com.android.settings.Settings (server)'
D/dalvikvm( 224): GC_EXTERNAL_ALLOC freed 32K, 42% free 3239K/5511K, external 2576K/2644K, paused 23ms
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '4084fa00 com.android.settings/com.android.settings.Settings (server)'
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 4012 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
D/BounceScrollRunnableDefault( 224): start(1332.9647), mBounceExtent:-21.0
D/BounceScrollRunnableDefault( 224): mBounceExtentCoef = -128.67554
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.026666667, mBounceExtent=-30.84343
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.048333332, mBounceExtent=-51.276398
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.05, mBounceExtent=-52.693928
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.07333333, mBounceExtent=-70.4532
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.095, mBounceExtent=-83.80916
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.11333334, mBounceExtent=-93.08541
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.115, mBounceExtent=-93.84585
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.13666667, mBounceExtent=-102.60366
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.165, mBounceExtent=-111.302734
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.19833334, mBounceExtent=-118.38868
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.2, mBounceExtent=-118.66973
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.23, mBounceExtent=-122.767204
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.26166666, mBounceExtent=-125.5091
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.26333332, mBounceExtent=-125.61828
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.28833333, mBounceExtent=-126.926056
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.325, mBounceExtent=-127.99971
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.34833333, mBounceExtent=-128.3451
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.35, mBounceExtent=-128.36285
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.37666667, mBounceExtent=-128.55804
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.37833333, mBounceExtent=-128.56577
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.40833333, mBounceExtent=-128.64888
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.41, mBounceExtent=-128.65123
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.44333333, mBounceExtent=-128.67313
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.445, mBounceExtent=-128.67346
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.46833333, mBounceExtent=-128.6754
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.47, mBounceExtent=-128.67543
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.49833333, mBounceExtent=-128.67554
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.5, mBounceExtent=-128.67554
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.53, mBounceExtent=-110.49808
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.55833334, mBounceExtent=-95.27566
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.585, mBounceExtent=-82.52803
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.6166667, mBounceExtent=-69.20207
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.65, mBounceExtent=-57.094025
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.675, mBounceExtent=-49.177414
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.705, mBounceExtent=-40.86313
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.7366667, mBounceExtent=-33.347794
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.765, mBounceExtent=-27.601503
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.795, mBounceExtent=-22.409983
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.8233333, mBounceExtent=-18.2545
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.8566667, mBounceExtent=-14.179998
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.8833333, mBounceExtent=-11.474887
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.91333336, mBounceExtent=-8.942376
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.945, mBounceExtent=-6.7758055
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=0.9716667, mBounceExtent=-5.297073
D/BounceScrollRunnableDefault( 224): run(), TimeFraction=1.0033333, mBounceExtent=-3.888849
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.LanguageSettings } from pid 224
W/ActivityManager( 133): Trying to launch com.android.settings/.LanguageSettings
D/ResourceType( 224): calling getConfigurations
D/ResourceType( 224): called getConfigurations size=63
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 17
D/dalvikvm( 224): GC_CONCURRENT freed 73K, 41% free 3318K/5575K, external 2837K/3093K, paused 2ms+5ms
W/AudioFlinger( 83): write blocked for 80 msecs, 6 delayed writes, thread 0x319a0
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 17
I/ActivityManager( 133): Displayed com.android.settings/.LanguageSettings: +410ms
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '407b8c30 com.android.settings/com.android.settings.LanguageSettings (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '407b8c30 com.android.settings/com.android.settings.LanguageSettings (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 18
V/SettingsProvider( 133): secure <- value= name=enabled_input_methods
V/SettingsProvider( 133): property: sys.settings_secure_version=5
V/SettingsProvider( 133): notifying: content://settings/secure/enabled_input_methods
V/SettingsProvider( 133): secure <- value= name=default_input_method
V/SettingsProvider( 133): property: sys.settings_secure_version=6
I/ActivityManager( 133): Config changed: { scale=1.0 imsi=310/260 loc=en_US touch=3 keys=1/2/2 nav=1/1 orien=1 layout=34 uiMode=17 seq=4 FlipFont=0}
V/SettingsProvider( 133): notifying: content://settings/secure/default_input_method
V/Mms/HVGALayoutParameters( 496): HVGALayoutParameters.<init>(11).
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 18
E/Sensors ( 133): LightSensor: debouncing current adc(672), report prev lux 5000.000000
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '4099d6f8 com.android.settings/com.android.settings.LanguageSettings (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '4099d6f8 com.android.settings/com.android.settings.LanguageSettings (server)'
D/dalvikvm( 133): GC_EXPLICIT freed 379K, 41% free 6540K/11015K, external 6662K/7823K, paused 148ms
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 19
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 19
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '406a6210 com.android.settings/com.android.settings.LanguageSettings (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '406a6210 com.android.settings/com.android.settings.LanguageSettings (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 20
V/SettingsProvider( 133): secure <- value=com.beautifulapps.superkeyboard.free/com.beautifulapps.superkeyboard.LatinIME name=enabled_input_methods
V/SettingsProvider( 133): property: sys.settings_secure_version=7
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4082e650
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 20
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 4017 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
continued:
D/StatusBarManagerService( 133): manageDisableList what=0x1 pkg=android
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '407d29d8 (server)'
D/dalvikvm( 303): GC_EXPLICIT freed 103K, 48% free 3640K/6919K, external 9235K/11034K, paused 84ms
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '407d29d8 (server)'
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10100000 cmp=org.jtb.alogcat/.LogActivity } from pid 133
D/StatusBarManagerService( 133): manageDisableList what=0x0 pkg=android
V/alogcat ( 790): started
I/alogcat ( 790): new intent: android.intent.action.MAIN
D/alogcat ( 790): stopping ...
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 21
D/alogcat ( 790): canceling periodic saves
V/alogcat ( 790): resumed
D/alogcat ( 790): starting ...
W/AudioFlinger( 83): write blocked for 86 msecs, 7 delayed writes, thread 0x319a0
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 21
D/dalvikvm( 790): GC_CONCURRENT freed 797K, 52% free 3611K/7431K, external 2005K/2108K, paused 2ms+4ms
D/dalvikvm( 790): GC_CONCURRENT freed 297K, 45% free 4099K/7431K, external 2005K/2108K, paused 2ms+4ms
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 3947 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
D/dalvikvm( 790): GC_CONCURRENT freed 578K, 41% free 4456K/7431K, external 2005K/2108K, paused 1ms+4ms
W/PowerManagerService( 133): Timer 0x7->0x3|0x3
D/dalvikvm( 790): GC_CONCURRENT freed 929K, 41% free 4577K/7687K, external 2005K/2108K, paused 1ms+9ms
E/Sensors ( 133): LightSensor: debouncing current adc(765), report prev lux 5000.000000
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '40aa9cb0 org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '40aa9cb0 org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/EventLogService( 317): Aggregate from 1326053530264 (log), 1326051774606 (data)
D/dalvikvm( 790): GC_EXTERNAL_ALLOC freed 1108K, 53% free 3674K/7687K, external 2095K/2108K, paused 35ms
D/dalvikvm( 317): GC_FOR_MALLOC freed 566K, 45% free 3679K/6663K, external 1596K/2108K, paused 28ms
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '40804360 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '40804360 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 22
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4085e9f0
W/AudioFlinger( 83): write blocked for 84 msecs, 8 delayed writes, thread 0x319a0
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 22
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 3992 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
D/dalvikvm( 224): GC_EXPLICIT freed 235K, 42% free 3471K/5895K, external 2605K/2756K, paused 40ms
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '40979598 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '40979598 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 23
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@409bb308
D/dalvikvm( 790): GC_FOR_MALLOC freed 507K, 52% free 3823K/7943K, external 2145K/2642K, paused 26ms
I/dalvikvm-heap( 790): Grow heap (frag case) to 8.093MB for 192410-byte allocation
W/AudioFlinger( 83): write blocked for 81 msecs, 9 delayed writes, thread 0x319a0
D/dalvikvm( 790): GC_FOR_MALLOC freed 12K, 51% free 3999K/8135K, external 2145K/2642K, paused 24ms
D/dalvikvm( 790): GC_FOR_MALLOC freed 125K, 53% free 3876K/8135K, external 2145K/2642K, paused 25ms
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.CHOOSER cmp=android/com.android.internal.app.ChooserActivity (has extras) } from pid 790
V/alogcat ( 790): save instance
V/alogcat ( 790): paused
W/ActivityManager( 133): Trying to launch android/com.android.internal.app.ChooserActivity
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 23
I/ActivityManager( 133): Displayed android/com.android.internal.app.ChooserActivity: +330ms
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 3995 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '409f1008 android/com.android.internal.app.ChooserActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '409f1008 android/com.android.internal.app.ChooserActivity (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 24
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.SEND typ=text/plain flg=0x3000000 cmp=com.google.android.gm/.ComposeActivityGmail (has extras) } from pid 790
W/ActivityManager( 133): Trying to launch com.google.android.gm/.ComposeActivityGmail
I/ActivityManager( 133): Starting: Intent { act=android.intent.action.SEND typ=text/plain flg=0x2000000 cmp=com.google.android.gm/.ComposeActivity (has extras) } from pid 464
D/alogcat ( 790): stopped
I/Gmail ( 464): calculateUnknownSyncRationalesAndPurgeInBackground: queueing
I/webclipboard( 464): clipservice: android.sec.clipboard.ClipboardExManager@405eec40
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 24
I/Gmail ( 464): calculateUnknownSyncRationalesAndPurgeInBackground: running
D/WML_SISO( 464): InitPasteboardJni
D/dalvikvm( 464): GC_CONCURRENT freed 693K, 43% free 3896K/6727K, external 2032K/2108K, paused 3ms+4ms
I/ActivityManager( 133): Displayed com.google.android.gm/.ComposeActivity: +1s444ms (total +1s478ms)
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '409f26d0 com.google.android.gm/com.google.android.gm.ComposeActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '409f26d0 com.google.android.gm/com.google.android.gm.ComposeActivity (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 25
W/AudioFlinger( 83): write blocked for 82 msecs, 10 delayed writes, thread 0x319a0
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 25
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 4000 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 26
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 26
D/dalvikvm( 496): GC_EXPLICIT freed 195K, 42% free 3379K/5767K, external 3224K/3980K, paused 74ms
D/BatteryService( 133): updateBattery level:91 scale:100 status:4 health:2 present:true voltage: 4003 temperature: 340 technology: Li-ion AC powered:false USB powered:false icon:17302239
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '409f26d0 com.google.android.gm/com.google.android.gm.ComposeActivity (server)'
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '409f26d0 com.google.android.gm/com.google.android.gm.ComposeActivity (server)'
D/dalvikvm( 464): GC_EXTERNAL_ALLOC freed 319K, 45% free 3715K/6727K, external 2096K/2108K, paused 25ms
D/dalvikvm( 790): GC_EXPLICIT freed 559K, 54% free 3777K/8135K, external 2585K/2642K, paused 60ms
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '409fcac8 AtchDlg:com.google.android.gm/com.google.android.gm.ComposeActivity (server)'
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '409fcac8 AtchDlg:com.google.android.gm/com.google.android.gm.ComposeActivity (server)'
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40596170
D/dalvikvm( 790): GC_CONCURRENT freed 575K, 48% free 4247K/8135K, external 2136K/2642K, paused 1ms+4ms
D/dalvikvm( 790): GC_CONCURRENT freed 661K, 44% free 4610K/8135K, external 2136K/2642K, paused 2ms+3ms
D/BatteryService( 133): updateBattery level:90 scale:100 status:4 health:2 present:true voltage: 3951 temperature: 330 technology: Li-ion AC powered:false USB powered:false icon:17302239
D/dalvikvm( 790): GC_CONCURRENT freed 1043K, 43% free 4709K/8135K, external 2136K/2642K, paused 2ms+8ms
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '409fbbe0 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '409fbbe0 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '407b35a8 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '407b35a8 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
V/AudioPolicyManager( 83): startOutput() output 1, stream 1, session 27
D/dalvikvm( 790): GC_FOR_MALLOC freed 1438K, 54% free 3790K/8135K, external 2145K/2642K, paused 26ms
W/AudioFlinger( 83): write blocked for 83 msecs, 12 delayed writes, thread 0x319a0
D/dalvikvm( 790): GC_FOR_MALLOC freed 107K, 54% free 3792K/8135K, external 2136K/2642K, paused 19ms
I/dalvikvm-heap( 790): Grow heap (frag case) to 7.982MB for 117686-byte allocation
D/dalvikvm( 790): GC_FOR_MALLOC freed <1K, 53% free 3907K/8263K, external 2136K/2642K, paused 19ms
D/dalvikvm( 790): GC_FOR_MALLOC freed 77K, 54% free 3829K/8263K, external 2136K/2642K, paused 21ms
I/dalvikvm-heap( 790): Grow heap (frag case) to 8.076MB for 176524-byte allocation
D/dalvikvm( 790): GC_FOR_MALLOC freed <1K, 53% free 4002K/8455K, external 2136K/2642K, paused 21ms
D/dalvikvm( 790): GC_FOR_MALLOC freed 115K, 55% free 3888K/8455K, external 2136K/2642K, paused 24ms
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40533698
V/AudioPolicyManager( 83): stopOutput() output 1, stream 1, session 27
I/ActivityManager( 133): Displayed android/com.android.internal.app.ChooserActivity: +375ms
I/Kineto::wifi( 233): onReceive Enter
V/Kineto::wifi( 233): RSSI_CHANGED_ACTION newRssi: -59
I/Kineto::wifi( 233): onReceive Exit
D/BatteryService( 133): updateBattery level:90 scale:100 status:4 health:2 present:true voltage: 3996 temperature: 330 technology: Li-ion AC powered:false USB powered:false icon:17302239
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '40a08c20 android/com.android.internal.app.ChooserActivity (server)'
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '40a08c20 android/com.android.internal.app.ChooserActivity (server)'
W/InputManagerService( 133): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4096f570
D/dalvikvm( 790): GC_CONCURRENT freed 1129K, 56% free 3768K/8455K, external 2585K/2642K, paused 2ms+8ms
D/dalvikvm( 790): GC_CONCURRENT freed 348K, 48% free 4457K/8455K, external 2585K/2642K, paused 2ms+5ms
D/InputDispatcher( 133): findFocusedWindow finished: injectionResult=-1, timeSpendWaitingForApplication=1581.0ms
D/dalvikvm( 790): GC_CONCURRENT freed 796K, 43% free 4889K/8455K, external 2585K/2642K, paused 2ms+4ms
I/InputDispatcher( 133): Delivering key to current input target: action: 0, channel '4090c2c0 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering key to current input target: action: 1, channel '4090c2c0 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 0, channel '4087b4e8 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
I/InputDispatcher( 133): Delivering touch to current input target: action: 1, channel '4087b4e8 AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity (server)'
Thanks.
Seemed like an awfully long file. I checked Hacker's Keyboard only, then had to reboot to get another keyboard. Trying to make sure that the logfile only saw Hacker's and errors.
Thanks again.
I was hoping for a txt attachment. :)
Let me look this over.
Are you not able to change to a working keyboard without rebooting in order to share the log via aLogcat?
In such a case, you'll need to go the adb route.
Do you have adb installed? If not, the forum maintains a mini SDK (just a zip file) that has just the few files you'll need.
Have you run adb before? If not, it's pretty simple and I can post instructions.
PS - Mac, windows, or linux?
Not unless I check all the keyboards. I have Super, GB, and Big Buttons. I unchecked them to make sure they wouldn't interfere with any results. That's why the reboot.
That is a txt file. I had to paste it in. How do I get the original to you since message here doesn't do attachments? I don't have anywhere to post it for download.
I'd have the same delivery problem using the computer ADB.
Thanks
Go ahead and check a working keyboard and then re-trace my suggested sequence.
When you rebooted, it lost the portion of the log of interest.
Message here does attachments on a desktop if you use the Advanced button, then go to the paper clip tool at the top of the entry tools.
Regardless, I'll PM you a private address you can use for me.
