AndroidMan1
Member
I am trying to update one of my old android apps. when i upload the new apk it says:
Google Play requires that the certificate used to sign the apk be valid until at least October 22, 2033. Create a new certificate.
It tells me to create a new certificate, but i don't want to create a new certificate as then it wont be an update:
The apk must be signed with the same certificates as the previous version.
Google has messed up here, how can i go about fixing this? Ive read on the internet you can somehow connect two certificates together (old one and new one with date bigger than 2033). Basically all i want to do is increase the certificate date to a date greater than 2033. ANY IDEA???
Thanks In Advance
Thanks In Advance
