cheeseburger
Hey, is it possible to connect the motorola milestone to the net via a pc?
I'm using a cable internet connection on my pc. My router is connected to the pc using cables. However, since my router isn't wireless, my milestone cannot connect to the internet via wifi. Is it then possible to connect the milestone to the computer via usb and use the internet the computer is on, just like how the tethering works, but only the opposite?
1. My laptop doesn't have a wireless card
2. My laptop is connected to a non-wireless router which is then only connected to the modem
3. I'm running on windows 7
thanks!!
thanks!!
