alexfree05
Hi guys,
I used to be an iphone 5 user,
but i just got my note 2 3 days ago and I love it soooo much.
i got a problem which bug me a lot..
I downloaded a few apps from play store, and place the icon on the home screen. few minutes later, the og icon changed to android bot icon for some reason, and with "loading" as the label..
I tried to uninstall and re-install, but it didn't work,,
This happened after I had mounted in the micro-sd card.
Then I un-mounted and re-install the apps again, still the same..
Do anyone have the same problem?
how can i solve this?
Thanks
Alex
Thanks
Alex
