Check to see what the battery is being used by. My guess is GMail is stuck trying to sync since reboot.
Mine is at close to 100% cause I can't stop playing with it!
I am not sure how to do that...
But, I realize, that the definition of awake time is the percentage of
active processor time since last charging.
When I fininshed the *228 procedure I unpluged the phone from the charger. So the awake time timer started at that point and naturally
the processor usage at that point was 100%.
Since then, as I put the phone sleep, each time I turned it on and
checked the awake time, it steadily decreased. Now it is alreay down to 13%.
So I panicked without reason, because I didn't understand well the meaning of awake time...
Peter
Battery instead of status. Same menu before that. Doesn't do the math for ya like before
