Help Help: Backup assistant issue + factory reset
So basically this happened to me. I was experimenting random reboots and made a hard reset in order to see if this fix the issue. Everything seems normal, bnut after I registered my google account the Backup assistant shows and try to connect to server but then came this messages "Network unavailable, please contact Verizon customer support for assistance". I cancel the message and the the Setup Accounts screen shows up, I click on "done adding accounts" then next and then another message appears "Sorry! The application My Accounts (process com.motorola.setup) has stopped unexpectly, please try again" and then I can do nothing, this screens continue showing. I pressed the haptic buttons and nothing happened. I can't go to home screen or even phone configurations. The only things that my phone can do right now y receive sms and calls. What can I do???? PLease help!!!!:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
You may be in the market for an SBF. Don't go try this til anyone else seconds it, but it sounds like you're having continuous FCs and can't access your accounts what-so-ever. An SBF will make it like it's just out of the box.
