I purchased an extended battery weeks ago (Qcell 4200mah) and have been pleased with the battery life so far. Big improvement over the stock battery...
Problem is, as soon as I unplug the charger, the battery level drops to around 87% immediately. It then drops at a normal rate until around 5%, and past that it takes forever to kill the phone.
It seems like the phone needs to be calibrated with the battery. I've done the recommended steps of draining it completely, then recharging to 100%, then draining it again and fully charging it. Still no luck. I do notice that if I plug the phone BACK in to charge after it drops to 87%, charge it to 100%, then unplug... it seems to drop at a normal rate from 100% like it should.
Any tips? I prefer not having to root my phone and get special software to do this. Thanks
