Help bug report says rooted never done
Ok well I dont know enough about . but the blue tooth has two look same but cant disable or see what permissions it has. And if there's anything else to on that bug report you need. I dont know enough goes forever
I'd like to see an adb logcat output.
From the command line on a PC running Linux or I believe windows .
It would look like
Code:
 adb logcat -d > logcat.txt
This would give you a nice long text file to look at....
Screenshots of a bug report aren't enough to diagnose the system properly.
But I noticed some reference to a problem in Bluetooth in the screen shot.
Of course it could be something unrelated....
Also let's keep it public so that if anyone else has the same problem they can learn from this to.
Mark as Unread Star Conversation Leave Conversation
Matthel14
Matthel14
Rank:
None
I try to when I let me disable them. it will not let me I have 2 different Bluetooth look exactly the same I tryed both I don't know exactly what I'm looking at that bug report do you need anything else out of it it goes on and on
Matthel14, 53 minutes ago
New
Report
Reply
are you are you telling me you have 2 Bluetooth on a single phone that definitely doesn't sound right
My phone just started acting really funny I try to upload some files and it keeps flashing a couple times and it won't send it
Not sure but I know my phone is getting slower and doing less things I wanted to do. This is in my system apps
Little spy tracker and this is been running 10 minutes and what it pulled
It looks like your signal wasn't very good when those logs were made. I don't see anything that looks very significant to me. I assume "little spy tracker" is the name of something you are using?
And as you are not rooted you won't be able to do much about system apps - that is normal and by design (if you gave all users root privileges the manufacturers would be swamped by people breaking their devices. You'd be amazed how often we've seen people post stories like "I rooted my phone and got rid of some system apps that I don't use/didn't recognise and now my phone won't start...").
I really don't see anything that looks remotely suspicious. I did think having Bluetooth listed twice was a little odd, but when I check my system apps I found the same thing.
When I tapped on each I saw one was version 8.0.0 and the other was 6.20.44. I can only assume that there are two Bluetooth services running for compatibility with older devices.
You've made several general statements about your phone not running correctly but you don't really elaborate. Can you be specific about what exactly isn't working? Or is behaving oddly? If it's just things in the logs that you don't recognize, then you will just drive yourself crazy looking for problems where none exist. Most people don't have a clue about what the log entries mean and if they see something like an error or failure they assume something is wrong.
Just got an vindictive ex /lil scared # help .
Amazing what a little paranoia can do. ;)
