Root Help - Can't flash radio?
blh2012
Hi guys.
Currently running the 0.97.10.0530 radio from the "Fix Everything" thread (PG86IMG.ZIP). Am trying to switch to radio 0.97.00.0518 (PG58IMG.ZIP).
I put the new radio at the root of my Sdcard as normal, then restarted to the bootloader, but it didn't recognize the new radio.
Instead, it just ran an error message a few times that said something like "PG86IMG NO IMAGE FOUND". PG86 is the radio I'm currently using, not the one I'm trying to flash to.
I searched the SD card to see if I had accidentally left a PG86IMG zip on my sd card but I didn't.
Anyone know why this radio won't flash?
Could it be because I'm using SOS ROM for the 3D which doesn't have a diagnostic mode?
Hi guys.
I searched the SD card to see if I had accidentally left a PG86IMG zip on my sd card but I didn't.Anyone know why this radio won't flash?
Did you rename it to PG86IMG.zip
