Help coming from Pre regarding contacts and task manager
rcyphermd
Android Expert
I am trying out the hero coming from Pre. So far I like it a lot. What is the easiest/fastest way to look up a contact to call them? The manual says (yes I read it!) that there are only 9 quick dials are available, and not when roaming. With the pre, I could type "jd" and john doe would pop up with all the phone numbers without entering any program or app. It seems I must go to people....menu....search people....then type. Is there a faster way? an app that improves this?
Also, when I use task manager, even after I close out some apps, they seem to start back up on there own. Example: navagtion, sprint tv, etc. How do I stop that?
Thanks in advance for helping an android newbie!
The easiest for me is go to a blank page and add a people widget and add your favorites i like that the best or use voice dial.
Just bring up the dialer and start typing the person's name. A list of matching names/numbers will start to appear in the background and narrow down the more you type. Tap the one you want to call and go from there.
It could be possible to change what search "engine" the search button uses by default to your contacts, i just use the people widget myself though.
