I just recently bought the MK808B with Android 4.1 and I can't connect to WiFi.
I see my WiFi network under the list of WiFi networks and it says:
I click it, type in my password, click connect, then it changes to
then to
But then nothing. No WiFi. I click it again and click "Connect" and absolutely nothing happens. It doesn't give me any error outputs or anything. It does say that the signal strength is "Good".
But I can't connect to any web pages and it says "No Internet connection 100%" when I click the little bar at the bottom.
mywifinetwork
Secured with WEP
mywifinetwork
Connecting...
then to
mywifinetwork
Saved, secured with WEP
