Help HELP! D2 stuck in bootloop
androidb
So I did something stupid and tried to put the Galaxy S status bar on the D2 without realizing it is for the X. Now it's stuck in an endless bootloop. What should I do?
I was trying to do the D2 2.2 SBF but how do I connect since it keeps rebooting?
EDIT: Found some info online during my panic. Allowed me to start the SBF, hopefully it works.
"Power on holding the power key and the Up arrow key on the keyboard. After the M logo appears, release the two keys.
That will put your Droid into the bootloader...then you can connect it to your PC via USB and use the SBF post to bring your phone back to normal."
I hope you have a D2 - your profile says DX. :)
If you have trouble connecting via USB try another USB cable...someone posted earlier today that they could not connect w/the USB cable that came w/their D2, but connected fine w/one that came w/their Blackberry...go figure.
Good luck.
