help dont know what i did :(
Nube here.....tried do more than what I now and don't know how to fix it.
So I used the cyanogen wiki to root my phone and I had cynaogen mod 4.2.14?
I wanted to switch to a recovery image that would allow me partition my sd card, so I deleted the old recovery image off sd added the new 1. Turned phone off booted while holding camera and power. Boots to the rainbow screen. Press action updates etc. then back to rainbow screen and says serial 0.Take battery out if I press home and power loads to the triangle exclamation mark screen?? If I let it boot reg I sign into gmail etc and back at
Firmware 1.0
Baseband 62.33.20.08h_1.22.12.29
Kernel 2.6.25_01843-gfea26b0
So how do I get back to be4 I started messing with stuff??? Some1 please help after this
After I get back to normal I give up on new things :(
email south69_dallas@yahoo.com or reply to thread please
Try pressing Alt+L on the exclamation mark screen. If it doesn't work, flash the old recovery into your phone (using fastboot). Tell me if it works.
ok so i boot it into recovery mode press alt + l on the exclamation triangle screen its says something about applying update etc then no update found. so i changed the name of the the mod to update(its a zip file) and then its allows it but then cancels because their is no signature???
As I said in my earlier post, go into fastboot and flash another recovery (you can use the one you had before this one). Then apply the rom you have (which you renamed to update.zip)
