Hi all. So I downloaded the language learning software Smigin a while back for a trip to Spain. It has a phrase builder in it, and as such, it downloads audio clips. Unfortunately, they show up in my Google Play Music app. I don't want that...at all. So, it looks like I have two options:
- Go one by one, clip by clip, and delete all 600 some OR
- I noticed that they are stored on my internal storage. So, the obvious choice is to simply delete them from my IS. However, there's a problem:
When I select the folder containing ALL the audio clips, and select Delete, I get a pop up message saying "unable to delete some documents". And by "some", it means "all".
Could this be because I uninstalled the app? Something else? Anyone have any idea?
TIA.
TIA.
