Help Downloading Tasker Profiles
reom_76
I recently got the Tasker app and am trying to get it to work for me. It seems one of the easiest way to make it do simple tasks is by downloading other users' profiles. I can find and download profiles via the wiki. Once I download the profile, the instructions say to go back into Tasker and go Menu -> Profile Data -> Import One Profile.
However, I don't have the "Profile Data" option under the menu. I only have Browse Profile, Preferences, Data, Info, and More. I thought it may be the "Data" option, but that just gives options for Clear, Backup, and Restore.
Has anyone else run into this or have any idea how I can fix it? Thanks in advance.
Tasker has evolved since those instructions were written. To import profiles with version 1.2, long press on the profiles tab and a menu will popup, with import being one of the options.
That did it. at first I was long pressing on the screen and not the tab. Thanks so much for your help.
