Help! either app or advice
Crashumbc
Android Expert
The goal:
I need to sync my google calendar(or directly with android phone) with groupwise at work
Constraints:
No groupwise mobile
no wireless updates
no automated "delegating" appointments (work blocks automated e-mail from sending to outside addresses)
Currently using:
Goupwise PDA connect with my WinMO phone (buying a incredible in 9 days)
What I've looked at:
CompanionLink cost 40$ plus they are stopping groupwise support
Ideally, I'd like something that works like PDA connect. It uses USB to manually sync with my current phone, I just plug it in at work in the morning and click sync.
Ok ideas? (yes I know Groupwise sucks)
I saw something about people putting Outlook on a PC along with the Groupwise client and it could be configured to "talk" to the Groupwise server... Anyone try do this?
sorry if this is the wrong forum I took the best guess I had.
You can also use this utility to sync Groupwise with Google, which in turn syncs with your phone. It is a desktop syncer, so you have to run it to make it sync.
www syncjob com (I'm new)
Right now it works from command line only (no UI), but that's going to change in a future version.
