Help: Facebook for HTC Sense Stops Unexpectedly
johnvm914
This is my first post, so please be kind. :)
I have the EVO and I recently added a new Facebook contact. When I go into people>online directories>facebook he shows up in my friends list (which is great that it synched up). When I select the contact, his details pop up fine (again great). However, when I select the refresh icon at the bottom (which is supposed to pull up his wall) I get the error message "The application Facebook for HTC Sense (process com.htc.socialnetwork.facebook) has stopped unexpectedly. Please try again." The only option I have is to select "force close" in the error window. This seems to be the only contact this is happening with, so I'm not sure what the problem is. I have tried logging out and back into Facebook for HTC Sense, but that has not solved the issue. Any thoughts?
mine used to do that too on my incredible and works now. Have you tried to clear the data in FB for HTC sense? or try to delete the sync account and re-add it.
