Ok so I need a notepad App! BUT... not just your ordinary notepad app!
I am in Law Enforcement and am desperately trying to find some sort of app out there that has editable fields in it...
IE:
A Field that I could rename FIRST NAME and then always be able to enter text after it
Preferably with a Comments section under neath it.
Alternatively...
I am also looking for a notepad that I can add subnotes to it, kinda like bullet points except they are completely separate notes that pertain in some way to the parent note.
Does anything like this exist??? It would help make my life SO much easier...
IE:
Alternatively...
