Help finding the regular android launcher
Jbrown93
Hi I cant find my regular android launcher. I was hoping to use this. However I can find my launcher pro and htc sense launchers. Thanks for any help
I'd like to know too. Seen videos showing how to switch it...but when I do, sense and launcherpro are the only options I have...no stock.
ok on home screen press
menu
settings
applications
manage applications
(you can go to running to make it easier) find launcher pro
scroll down a little
it says launch by default click CLEAR DEFAULTS
then its back to normal ;)
People, it's gone. It was removed/disabled with 2.1 update 1.47.651.1; It is still gone with 2.2 Froyo.
It has come up 3 other times in the last 2 days in individual topics (see below). And mentioned countless other times in other unrelated threads. Not to mention the hemming and hawing about it a month ago when 1.47.651.1 was released.
http://androidforums.com/htc-evo-4g/135727-how-do-i-disable-sense.html
http://androidforums.com/htc-evo-4g/140224-2-2-get-rid-default-launcher.html
http://androidforums.com/htc-evo-4g/141776-can-sense-ui-turned-off-stock-turned.html
You can root and flash a ROM that includes it to get it back if it is that important to you.
