pschmutzler
Last week, my unrooted, locked VZW G-Nex decided that it didn't want to boot up anymore. I had not downloaded any new OS updates or apps within about 2 weeks, so it seems as if it was a random stroke of fate.
It will either stick on the Google splash screen, or (if it boots to the OS) it will reboot endlessly after a few seconds. Also, using the hard reset in the bootloader does not work. It says that it works, but still has all of my data and settings when I can get into the OS for a few seconds.
I've tried following the steps found here to restore it to the factory image, but keep getting stuck.
After I have unlocked it and restart the bootloader, it comes back on re-locked.
I really don't care whether I use the factory image or something like Cyanogen, but can someone help me figure out where I'm going wrong? Thanks.
If this is the wrong place to post, my apologies. First post.
