Apps Help for app with SQLite -graphical table?
Hi
I have a big problem and I am new in Andoid development applications.
The problem is :I have to make app which create a dinamicaly table (for Students) to add Student and delete students and to show garphicaly this table.And every time when I delete Student or add one the table graphically to delete the same row from the table or to add new row.(in the layout may be).
I create some code but when I run the application It stop unespectedly.I put the code.Please help!!Thank you .
P.S I hope you inderstand what the application is about.If you do not understand something just ask me .
This is the core for class HelloTable.java
package bg.example;
import android.app.Activity;
import android.database.Cursor;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
public class HelloTable extends Activity {
private Button create;
private Button show;
private Button add;
private Button addobj;
public EditText text1;
public EditText text2;
public EditText text3;
public EditText text4;
private Button editobj;
private Button deleteobj;
DBAdapter db = new DBAdapter(this);
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
create=(Button)findViewById(R.id.create);
show = (Button) findViewById(R.id.show);
addobj=(Button) findViewById(R.id.addobj);
add=(Button) findViewById(R.id.add);
deleteobj=(Button) findViewById(R.id.delete);
editobj=(Button) findViewById(R.id.edit);
create.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
findViewById(R.id.enterLayout).setVisibility(View.GONE);
findViewById(R.id.outputLayout).setVisibility(View.VISIBLE);}});
addobj.setOnClickListener(new View.OnClickListener() {
findViewById(R.id.addLayout).setVisibility(View.VISIBLE);}});
add.setOnClickListener(new View.OnClickListener() {
text1 = (EditText) findViewById(R.id.entry1);
String abrtext1=text1.getText().toString();
text2 = (EditText) findViewById(R.id.entry2);
String abrtext2=text2.getText().toString();
Integer abrtext= Integer.parseInt(abrtext2);
text3 = (EditText) findViewById(R.id.entry3);
String abrtext3=text3.getText().toString();
text4 = (EditText) findViewById(R.id.entry4);
String abrtext4=text4.getText().toString();
db.open();
long id;
id = db.insertStudent(
abrtext1,abrtext,abrtext3,abrtext4);
db.close();
findViewById(R.id.addLayout).setVisibility(View.GONE);
findViewById(R.id.enterLayout).setVisibility(View.VISIBLE);}});
deleteobj.setOnClickListener(new View.OnClickListener() {
findViewById(R.id.deleteLayout).setVisibility(View.VISIBLE);
db.open();
Integer fn=Integer.parseInt(abrtext2);
db.deleteStudent(fn);
db.close();
editobj.setOnClickListener(new View.OnClickListener() {
findViewById(R.id.outputLayout).setVisibility(View.GONE);
db.open();
db.updateStudent(abrtext1,abrtext,abrtext3,abrtext4);
db.close();
//mtranslate.setOnClickListener(new View.OnClickListener() {
//public void onClick(View v) {
//here have to be not secondwindow.class but for data base activity
//Intent i = new Intent(SecondWindow.this, FullName.class);
//startActivity(i);
show.setOnClickListener(new View.OnClickListener() {
//---get all students---
db.open();
Cursor c = db.getAllStudents();
if (c.moveToFirst())
do {
DisplayStudents(c);
} while (c.moveToNext());
db.close();
// Intent i = new Intent(HelloTable.this, TableActivity.class);
//startActivity(i);
public void DisplayStudents(Cursor c){
Toast.makeText(this,
"id: " + c.getString(0) + "\n" +
"ISBN: " + c.getString(1) + "\n" +
"TITLE: " + c.getString(2) + "\n" +
"PUBLISHER: " + c.getString(3),
Toast.LENGTH_LONG).show();
this is the helping class DBAdapter.java
package bg.example;
import android.content.ContentValues;
import android.content.Context;
import android.database.SQLException;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteOpenHelper;
import android.util.Log;
public class DBAdapter {
//constant from type String
public static final String KEY_NAME = "name";
public static final String KEY_FN = "fnumber";
public static final String KEY_CURS="curs";
public static final String KEY_SPEZ = "spezialnost";
private static final String TAG = "DBAdapter";
private static final String DATABASE_NAME = "studentsSU";
private static final String DATABASE_TABLE = "students";
private static final int DATABASE_VERSION = 1;
private static final String DATABASE_CREATE =
"create table titles (fnumber integer primary key not null, "
+ "name text not null, fnumber text not null, curs text not null "
+ "spezialnost text not null);";
private final Context context;
private DatabaseHelper DBHelper;
private SQLiteDatabase db;
public DBAdapter(Context ctx)
this.context = ctx;
DBHelper = new DatabaseHelper(context);
private static class DatabaseHelper extends SQLiteOpenHelper
DatabaseHelper(Context context)
super(context, DATABASE_NAME, null, DATABASE_VERSION);
@Override
public void onCreate(SQLiteDatabase db)
db.execSQL(DATABASE_CREATE);
@Override
public void onUpgrade(SQLiteDatabase db, int oldVersion,
int newVersion)
Log.w(TAG, "Upgrading database from version " + oldVersion
+ " to "
+ newVersion + ", which will destroy all old data");
db.execSQL("DROP TABLE IF EXISTS titles");
onCreate(db);
//---opens the database---
public DBAdapter open() throws SQLException
db = DBHelper.getWritableDatabase();
return this;
//---closes the database---
public void close()
DBHelper.close();
//---insert a student into the database---
public long insertStudent(String name, Integer fn, String curs,String spez)
ContentValues initialValues = new ContentValues();
initialValues.put(KEY_NAME, name);
initialValues.put(KEY_FN, fn);
initialValues.put(KEY_CURS, curs);
initialValues.put(KEY_SPEZ, spez);
return db.insert(DATABASE_TABLE, null, initialValues);
//---deletes a particular student---
public boolean deleteStudent(Integer rowId)
return db.delete(DATABASE_TABLE, KEY_FN +
"=" + rowId, null) > 0;
//---retrieves all the Students---
public Cursor getAllStudents()
return db.query(DATABASE_TABLE, new String[] {
KEY_NAME,
KEY_FN,
KEY_CURS,
KEY_SPEZ },
null,
null,
null,
null,
null
//---retrieves a particular Student---
public Cursor getStudent(long rowId) throws SQLException
Cursor mCursor =
db.query(true, DATABASE_TABLE, new String[] {
KEY_NAME,
KEY_FN,
KEY_CURS,
KEY_SPEZ
KEY_FN + "=" + rowId,
null,
null,
null,
null,
null);
if (mCursor != null) {
mCursor.moveToFirst();
return mCursor;
//---updates a Student---
public boolean updateStudent( String name,
Integer fn, String curs,String spezialnost)
ContentValues args = new ContentValues();
args.put(KEY_NAME, name);
args.put(KEY_FN, fn);
args.put(KEY_CURS, curs);
args.put(KEY_SPEZ, spezialnost);
return db.update(DATABASE_TABLE, args,
KEY_FN + "=" + fn, null) > 0;
the main.xml code :
xml version="1.0" encoding="utf-8"?>
RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"​
android:layout_width="fill_parent"​
android:layout_height="fill_parent"​
<RelativeLayout​
android:id="@+id/enterLayout"​
android:visibility="visible" >
Button​
android:text​
="CREATE TABLE"​
android:layout_width​
="fill_parent"​
android:layout_height​
="wrap_content"​
android:id​
="@+id/create"​
android:textStyle​
="bold"​
Button>​
Button android:text="SHOW"​
="fill_parent"​
="wrap_content"​
android:id​
="@+id/show"​
android:textStyle​
="bold"​
android:layout_below​
="@+id/create"​
Button>​
RelativeLayout>​
RelativeLayout​
android:id="@+id/outputLayout"​
android:visibility="gone"​
Button​
android:text​
="ADD OBJECT"​
="fill_parent"​
="wrap_content"​
android:id​
="@+id/addobj"​
android:textStyle​
="bold"></Button>
Button​
android:text​
="DELETE OBJECT"​
="fill_parent"​
="wrap_content"​
android:textStyle​
="bold"​
android:id​
="@+id/delete"​
="@+id/add"></Button>
Button​
android:text​
="EDIT OBJECT"​
="fill_parent"​
="wrap_content"​
android:id​
="@+id/edit"​
android:textStyle​
="bold"​
="@+id/delete"></Button>​
RelativeLayout>
RelativeLayout​
android:id="@+id/addLayout"​
android:visibility="gone" >​
TableLayout​
android:id="@+id/table"​
android:layout_width="wrap_content"​
android:layout_height="wrap_content"
android:stretchColumns="*"​
android:background="#ff0000">
TableRow
android:layout_margin="1dp">
TextView
android:text="Name"
android:background="#000000"​
android:textSize="20sp"/>​
<EditText
android:id="@+id/entry1"
android:background="@android:drawable/editbox_background"
TableRow>​
TableRow
android:layout_margin="1dp">​
<TextView
android:text="FN"
<EditText
android:id="@+id/entry2"
</TableRow>​
TableRow​
<TextView
android:text="Kurs"
<EditText
android:id="@+id/entry3"
android:background="@android:drawable/editbox_background" />
</TableRow>​
TableRow​
<TextView
android:text="Spezialnost"
<EditText
android:id="@+id/entry4"
android:background="@android:drawable/editbox_background"/>​
</TableRow>
TableLayout>​
<Button
android:layout_below="@id/table"​
android:id="@+id/add"​
android:text="OK"
android:layout_width="200dip"​
android:layout_height="80dip"
android:textStyle="bold"​
android:layout_marginLeft="240dip">
Button>​
</RelativeLayout>​
<RelativeLayout​
android:id="@+id/deleteLayout"​
TextView
android:text="Enter Fakultenet nomer:"
android:textSize="20sp"​
android:id="@+id/text"/>
EditText
android:id="@+id/fntext"
android:layout_below="@+id/text" />
Button​
android:text​
="delobj"​
="fill_parent"​
="wrap_content"​
android:id​
="@+id/delobj"​
android:textStyle​
="bold"​
="@+id/fntext"></Button>​
RelativeLayout>​
RelativeLayout>​
the table.xml
xml version="1.0" encoding="UTF-8"?>
TableLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:stretchColumns="1">
<TableRow >​
<TextView
android:layout_column="1"​
android:text="#"
android:padding="3dip"
android:id="@+id/nomer"
android:layout_height="wrap_content"​
android:textSize="20sp"></TextView>​
<View android:id="@+id/View01"
android:background="#FF0000"
android:layout_width="2dip"
android:layout_height="30dp"></View>​
<TextView
android:layout_column="2"
android:text="Name"
<View android:id="@+id/View02"
android:layout_height="30dp"​
android:layout_width="2dip">​
</View>​
<TextView
android:layout_column="3"
android:text="Student number"
android:padding="3dip"​
android:textSize="20sp" />
<View
android:layout_width="2dip"​
android:layout_height="30dp"/>​
<TextView
android:layout_column="4"
android:text="Major"
TableRow>
<View
android:id="@+id/View03"
android:layout_height="2dip"
android:background="#FF0000"></View>
</TableLayout>
addobject.xml:
xml version="1.0" encoding="UTF-8"?>​
android:orientation="vertical"​
android:layout_height="fill_parent">
TableLayout​
TableRow
TextView
android:text="Name"
<EditText
TableRow>​
TableRow
<TextView
android:text="FN"
<EditText
</TableRow>​
TableRow​
<TextView
android:text="Kurs"
<EditText
</TableRow>​
TableRow​
<TextView
<EditText
android:id="@+id/entry5"
</TableRow>
TableLayout>​
<Button
android:text="ADD"
Button>​
</RelativeLayout>
Hello, I have similar problem. I found an example: Android SQLite Basics: creating and using a database, and working with sqlite3 | Screaming Penguin and at first evrerythin was working fine, but when I tried to change the name of table (from table1 to let's say table123).
I get this error:
03-04 20:31:45.876: ERROR/AndroidRuntime(727): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.demo.notepad1/com.android.demo.notepad1.Notepadv1}: android.database.sqlite.SQLiteException: no such table: table123: , while compiling: SELECT _id, title, body FROM table123
how can I solve this problem? It looks like I can't add new table?
