Root help for root my epic
nerydlg
hi guy's I'm new in this world of android. I trying root my phone one click root exploitv2.2.4 but when i ran "run.bat" return
Code:
C:\samsung>run.bat
exploit and busybox made by joeykrim and one click installer made by noobnl
Presione una tecla para continuar . . .
copy and run the exploit (may take 2 minutes)
57 KB/s (5392 bytes in 0.091s)
4 KB/s (88 bytes in 0.018s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={2382, 2382}
[*] Searching for adb ...
[+] Found adb as PID 2364
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
make it RW and move files
mount: Operation not permitted
failed to copy 'joeykrim-root.sh' to '/system/bin/joeykrim-root.sh': Read-only f
ile system
failed to copy 'jk-su' to '/system/bin/jk-su': Read-only file system
failed to copy 'playlogo-orig' to '/system/bin/playlogo-orig': Read-only file sy
stem
failed to copy 'playlogo' to '/system/bin/playlogo': Read-only file system
failed to copy 'busybox' to '/system/bin/busybox': Read-only file system
failed to copy 'resolv.conf' to '/system/bin/resolv.conf': Read-only file system
failed to copy 'remount' to '/system/bin/remount': Read-only file system
set permission
Unable to chmod /system/bin/joeykrim-root.sh: No such file or directory
Unable to chmod /system/bin/playlogo: Read-only file system
Unable to chmod /system/bin/busybox: No such file or directory
Unable to chmod /system/bin/remount: No such file or directory
Unable to chmod /system/bin/playlogo-orig: No such file or directory
push any key to reboot the phone
I install terminal emulator for test root, when i type su return su:not found
this is description of my phone
firmware 2.2.1
kernel 2.6.32
num. app. FROYO.DK28
please heeelp :(
and sorry for my poor english
i have the same problem as nerydlg....
i have usb debugging on, current samsung driver downloaded from samsung website..and the root file on the c:/ drive also have downloaded sdk manager..
i've tried uninstalling the driver..and re-installing with the driver i download from samsung..
i ran cmd as an admin user...
i ran run.bat over and over trying diff methods such as takng the battery out for 30seconds and re-trying..
tried it with sd card mounted and un-mounted...
any suggestion or advice would be greatly appreciated..thanks you guys....
What works for me is ......turn on usb debugging and stay awake and mount the phone as well..... run "run.bat".....when it gets to the part about re logging in to adb.....right click the adb file and click run as administrator....also open task manager and repeatdley kill the adb process in combination with running the adb file as administrator and then the run.bat file will everntually respond.......works for me every time
