HELP! G1 with missing android market
my friend just gave me his g1 and I got into the phone with ease it works fine but then I noticed that there was no android market. I looked for the icon I hard reset the phone. I've done everything I can think of is there anyone who can help me I would greatly appreiciate it.
Try making a shortcut manually (ie, see if it shows up in the list of icons to add).
Maybe he put a custom ROM on there and didn't finish the job? What version is this G1 runnning? I think the highest official ROM is 1.6.
If there is a market entry under Settings | Applications I'd clear data and see if that helps. If not, I think the next step is to reset the phone:
Settings | SD card & phone storage | Factory data reset
If you have an option to back up the phone before the reset that would be useful. Caveat: I think you have to reassociate with your Google account after the reset.
