Help help!galaxy ace problem!must help!please!!
uchiha907
hi!i have a problem.after using clockwork my phone keeps showing "android" on home screen.please help me!thanks!!i will appreciate any help..thanks in andvance!!
Please tell your problem in detail so that I can help you? First of all, is the problem like this:
When you switch on your phone, does in only show "Android" and get stuck like that?
first i downloaded clockwork and install it to my ace.after that my phone got stuck on boot loop.no problem from there,before i just clear or delete the cache and reboot it,it would easily restore the phone and i can use it afterwards.but now when i clear or delete the cache and reboot the phone after the samsung logo "android" would appear immediately.i tried restoring the phone but still it keeps on showing "android".is my phone brick?i also install cyanogen for the hope that my phone would work.still stuck on "android".any tips?help?anything would do.thanks.:)
i would download an official stock rom,
then put this stock rom .zip on your sd card ,
put sd card into your device,
hold volume down and then press and hold the power button while holding the volume down, when the boot menu comes up select install from sd,
find the .zip stock rom you added to the sd ,
click install , ok
when install is complete reboot the device, voila
:D
click install , ok
:D
phew!thanks for your effort. i really appreciate your help.cant wait to try it later.i kinda lose my hope with my ace.but with your help i got my hope back.hihi^^
so i'll just download the original rom of the ace,put it on my sd card,insert the card to the phone,apply the .zip file and reboot the phone.cool!hope it works.either ways still thanks for your help...if it works can you help me on installing CWM?hehe if it's ok with you.
I also used the Cyanogenmod rom and I also faced the same bootloop you were facing in the starting! But then I went to recovery mode and cleared cache and did a factory reset and the phone worked perfectly!
still not working.it seems like the ace wont read my sd card.but when i connect it to the computer the files are there.it only read some of the files on my card.can you give me the link to the stock rom your talking about?maybe i downloaded the wrong one.thanks
