Root Help! Galaxy Ace Urgent Problem
Velorum
Hello, Today i have an issue with my Galaxy Ace. I decided to upgrade my Galaxy Ace at version 2.3.4 (Rooted) to this CyanogenMod i found today.
So, after placing the custom rom into my sdcard, i booted my phone into recovery mode and pressed the update option. It seemed to update normally. After the installation was completed, the phone rebooted and after the normal Galaxy Ace startup, Instead of the Samsung logo flashing, It showed a word "ANDROID" with spaces in between and in Times New Roman. Then, after 10 minutes, it was still at that same black screen with the "ANDROID". Then, i tried going into recovery mode and i tried to factory reset it, it showed
"E: format_volume : rfs format failed on /dev/stl13
Formatting /cache...
E: format volume: rfs format failed on /dev/stl14
Data wipe complete."
Then, i tried rebooting the phone. The same thing appeared.
So, Can anyone help me PLEASE?
Hi, I have same problem. Have you revive your ACE?
flask a fresh stock rom using odin
