Root (Help) getting data connection metropcs
mteezey
I just bought a dx2 and had it flashed to metro. I flashed my nv item and used root explorer to put the u2nl files and autostart. Sh in the proper places. As well as following the data provisions for metro. Bit still have no data connection. Can anyone help or share what method they used of they have their phone working on metros network. Thanks
Got it working. Got stuck in bootloop and had to sbf once I programmed for metro again everything worked.
Are you getting 3G connection? All I'm able to get is X1 and it's like pulling teeth... if you are getting 3G, would you be kind as to post your settings please... thank you in advance.
