kjsoccerdude
Just got Android put on my Touchpad finally. Thought it would be a lot harder than it turned out to be.
Well of course I want to put some emulators on it right away. Problem is if I have the TP running Android and hook it up to my computer it says it's installing the drivers and eventually that fails and it won't detect the TP. But if I load in in WebOS it detects it and I can open up the Touchpad and look at all the files.
So I imagine I need to download the file for an emulator and put it in the right spot to get it to run on Android. The problem is I have no idea which folder I should put the emulator file into.
Any help would be appreciated. If you need any more info from me let me know and I'll respond with it.
EDIT: So I just realized I likely posted this in the wrong section. I took a quick look around to try to find the right spot before posting but didn't see much else. Right after I posted it I realized there is a Touchpad specific section. Sorry about that.
