Help Help, Getting mtp mode error when using flashtool
Hi im trying to flash my xperia s to the latest jellybaby firmward and im using flash tool, when i connect my phone and attempt to flash it i get the following message-
01/051/2013 14:51:42 - INFO - <- This level is successfully initialized
01/051/2013 14:51:43 - INFO - Flashtool Version 0.9.9.0 built on 2012-11-13 22:53:30
01/051/2013 14:51:43 - INFO - You can drag and drop ftf files here to start flashing them
01/051/2013 14:51:51 - INFO - Device disconnected
01/054/2013 14:54:05 - INFO - Selected LT26i_6.2.B.0.200_WORLD.ftf
01/054/2013 14:54:05 - INFO - Preparing files for flashing
01/056/2013 14:56:17 - INFO - Please connect your device into flashmode.
01/008/2013 15:08:23 - INFO - Opening device for R/W
01/008/2013 15:08:24 - ERROR - Drivers need to be installed for connected device.
01/008/2013 15:08:24 - ERROR - You can find them in the drivers folder of Flashtool.
01/008/2013 15:08:25 - INFO - Start Flashing
01/008/2013 15:08:25 - INFO - Processing loader
01/008/2013 15:08:26 - INFO - Checking header
01/008/2013 15:08:26 - INFO - Ending flash session
01/008/2013 15:08:26 - ERROR -
01/008/2013 15:08:26 - ERROR - Error flashing. Aborted
01/008/2013 15:08:26 - INFO - Device connected in flash mode
01/008/2013 15:08:36 - INFO - Device disconnected
01/008/2013 15:08:44 - INFO - Device connected with USB debugging off
01/008/2013 15:08:44 - INFO - For 2011 devices line, be sure you are not in MTP mode
Any ideas? thanks
i have same error with flash tool, but after i use old version flash tool and update successful :)
version i use: flashtool-0.9.10.1-windows
C:Flashtool/Drivers/flashtool drivers.exe
Run that and select either Xperia S or lt26i i think the code name is. See how that goes.
help mine is xperia z3 D660e with locked bootloader and can't be unlocked same issue but it powers on but stuck on logo even charging same its soft bricked but flashtool gives same thing
