Root HELP! Hard Bricked Kyros MID9742-8
Kpatton
I REALLY NEED HELP! :confused: I think I may have hard bricked my Coby Kyros MID9742-8 :(
It won't turn on anymore, the reset button does nothing and it won't boot into recovery. At first I thought the battery died but after an over night charge I figure that isn't the problem. When I connect to pc via USB it makes the 'device connected' sound and I see the tablet (VID_1f3a_PID_efe8) in the device manager but nothing beyond that.
Here's what I did to it.
I installed Steev's custom ROM (with livesuit v.1.07) which worked fine for about 20 minutes then my screen went haywire and started flashing lines, and touch screen was unresponsive. I tried reflashing the custom ROM again about 4 times before flashing Steev's stock ROM. That put me at the unlock screen but still no response from the touch screen. After that I tried reflashing stock a couple more times, same thing. Then the last time when the first window came up in livesuit with a no and yes, I clicked yes and it formatted. It's been in it's current state since.
Hello Kpatton. Sorry to hear of your troubles, I have moved this to the All things root section, to hopefully get your thread the best eyes on the problem. Thanks for signing up! :)
I have the same device, and Steev's ROM was working "ok" on it, then I am not even sure what I did. Now it says that the internal memory is 0. Can't install anything, can't even connect to the computer because it won't install PDANet. Wipe/Reset did nothing. Every time I turn it on, it asks for the time zone, etc. SO mad at myself, and can't find a solution for this.
