Root Help!!! here is what i did
tyrewiz
i can't get it to root here is what i did
ONE CLICK ROOT on dl09*** CONFIRMED WORKING
i followed all instructions and here is a paste of what it says
* Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
* Testing if your device is connected
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I50012e5c973 device
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
794 KB/s (0 bytes in 1867568.002s)
91 KB/s (0 bytes in 26264.000s)
1116 KB/s (0 bytes in 196521.000s)
84 KB/s (0 bytes in 5392.000s)
8 KB/s (0 bytes in 281.000s)
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait
* About to exploit your device
* This will take about 3 minutes
* If it doesn't respond after waiting 5 minutes then it probably failed,
* so you should close this and run again
* Start Time: 14:51:48.64
** Successfully exploited, installing permanent root files and deleting temp fil
es
mount: Operation not permitted
/data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
/data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file syste
m
/data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file
system
Unable to chmod /system/xbin/su: No such file or directory
Unable to chmod /system/xbin/busybox: No such file or directory
* Restarting your phone now.
* Complete
Please help!!!
