Help Help! Home button issue
plesau
[FONT=&quot]Hi,
I need help!
I gave to try out my galaxy s3 to my friend. And after he gave it back every time i press the home button it sends me to the wrong home screen slide.
http://s14.postimage.org/a2ffkolc1/samsung.png
If you open the link you will see: the red circle indicated what slide is being opened after pressing the home button. And the green circle shows which slide should be opened.
I cant find proper settings to fix it.
:confused:[/FONT]
its quite simple just pinch the screen and click on the home icon(top right) to set which home screen should show up when u press the home button
