I have EL29 Galaxy S2 from Sprint. I only have a mac and would like to root my phone. Does anyone have advice that has rooted their Galaxy on a mac? Any links or advice would be really appreciated. Thank you.
When you use a Mac you should look for Odin cause the developer usually put a Mac version in the files and if it doesn't ask the developer cause he might have what you are looking for.
