Nope. In Screen Lock And Security, I only have the option to confirm the direction of the swipes.Does this work? (from bell canada)
- Touch Apps. You can remove any screen locks that you've set up on your Samsung Galaxy S6. ...
- Touch Settings. ...
- Scroll to and touch Lock screen and security. ...
- Touch Screen lock type. ...
- Enter your password. ...
- Touch NEXT. ...
- Touch None. ...
- The screen lock has been turned off.
To the first two replies: No, no, and no. To the last one, I don't know what that means. What is Tasker?I remember that on my S4, if you had settings applied to automatically lock the screen with PIN after screen timeout, then you automatically had a swipe to unlock every time you had a PIN entry. I didn't want to get rid of PIN protection, but it seemed ridiculous to have to do both (PIN and swipe). With root, I mimicked screen lock / PIN function based on time delay after screen-off using Tasker and was able to keep PIN protection without having any swipe screen.
I think on Samsung phones that Swipe to unlock is the default until you set up a pin or pattern lock.
