Help help - how do you manage files on SD - delete/move?
InGearX
UPDATE - this appears to be a known - issue -
with Android 4.4 KitKat, a change in the way the operating system gives read and write permissions to apps has caused a bit of a brouhaha among Android users. ... the ability of third-party apps to freely write to SD card has been crippled.
http://gs4.wonderhowto.com/how-to/b...ns-android-4-4-kitkat-your-galaxy-s4-0152036/
this is insane
how could they change such fundamental and critical functionality without giving us an option!?
I paid $$ for my phone due to this functionality - to use my SD card in it ..
all the NON ROOTED users - is there any solution?
my initial post:
when I try to delete SOME files from SD card using
native File Manager - it says "failed to delete"
ES File explorer - it says "cannot be deleted"
reboot to no avail
and even if I manage it via USB using a PC - it says - "storage is write-protected"
only solution is to take out the card physically put it into an adapter and into a PC to manage it :/
I think I was able to do it ..
till some update :/
please help ..
how do you do it?
how can it be done?
thank you ..
I am on SM-N900 not rooted
4.4.2
In app drawer you got Samsung.. with some apps.. like Internet, Calculator, Downloads, S translator or so. There is also an app called My files or similar.. Just open All.. navigate.. move, delete.. its a powerful file explorer with all rights in your system.
Hope this help you
