Root help! how to change color apk
morro
Hello! I'm trying to change the color for the phone apk icon (Touchwiz), green to blue. I tried using apktool for android because I don't have a computer but I have no idea how to use it. Maybe thats not the way to do it. Im new to theming so I'm clueless. LOL. Rush rooted, anykernel 3.2.2. Xposed installer has some options for touchwiz but I don't know if its possible for theming single apks. Any help will be appreciated. Thanks in advance.
Have you set system as rw then the apktool folder as the work space then import both frameworks? The icon your looking for is in seccontact.apk if I'm not mistaken
How do I do that? Could you provide me a step by step guide, please? Thanks in advance K Rize.
The icon I'm looking for us for the dialer app the green square with the white phone in it, I want to change color green to blue. Thanks K Rize.
Thanks Slayer72 ill check it out, I've heard about nova launcher. Well, I will give it a try. So, theming an app or icon would be complicated I mean im not a advance knowledgeable android user. Thanks
You should update and buy Nova Prime to unlock all of the features. it's my fav. Launcher lol
