HELP: How to DISABLE Lock screen, PIN or password request
biga57
Hi,
on my HTC One S, 4+, Android version just upgraded to 4.1.1, Software number: 3.14.709.102
I just set up my VPN. (settings> More >VPN> ....
Everytime I try to connect through VPN the phone asks me to set a lock screen PIN or password before I can use credential software.
I only have two options: Cancel and OK. if I cancel I cannot connect with my VPN. If I choose OK than I need to set up the PIN , or password or the pattern unlock screen.
I did choose the pattern and it is so boring and time consuming that I disabled it immediately.
Now back to square one. It seems I hve no way to disable this request and avoid setting this security screen lock options to reach my VPN and connect.
Any help ??? :)
